Wickes Oak Veneer Doors and Oil based varnish
17 Jan 2011
Manchester
Hi All
I have these Doors :
http://www.wickes.co.uk/invt/214699
And this varnish:
http://www.ronseal.co.uk/products/outdoor-varnish
The doors instruction state that Wickes Water Based Varnish must be used to seal the door completely, and oils and waxes should not be used. I interpret this as meaning they don;t want we to use danish oil etc.
I can;t see a problem in using the oil based varnish i have, but can someone advise me otherwise ?
I don;t want a disaster on my hands!
Andy
I presume you are using it as an interior door in which case I can't see a problem using the varnish you plan to use other than it is much better and more expensive than you need to use.
If there was a problem however Wickes could refuse to replace it under guarentee
Thank you ! I'm planning on thinning the first coat 50/50. Then 2 more coats of un thinned. Does that sound right ? (ps.. I have never varnished anything in my life, but done plenty of glossing etc.)
Andy
