mattbb
Joined: 28 Sep 2005 Posts: 2 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Wed Sep 28, 2005 9:22 am Post Subject: Adding Rad |
I wish to add an extra rad to my system into an extension.
The best place to pick up the system is in the upstairs bedroom and drop it out through the wall and down.
The new rad is 400 x 2000mm high, my existing system has 8mm copper from the rads `T`ed into a 15mm run under the floor.
It has a feed and return system and a pressure unit in the airing cupboard, it is not a combi boiler.
If i join into the 15mm copper with plastic and drop it out through the wall down to ground level do i need to then reduce to 8mm before going into the rad to keep the system flow the same or will i need to stay at 15mm because of the rad size? |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
mattbb
Posted: Wed Sep 28, 2005 10:07 am Post Subject: |
my other worry is i cant see past the one rad in the bedroom so i don't know how many rads are already coming off the 15mm, and how is the best way to know if i have the balance right in the system without a thermostat ? |
slippyr4
Joined: 12 Jul 2005 Posts: 681 Location: Bedfordshire, United Kingdom Thanked: 0 times
