Adam_151 said:so then ban, you expecting the predicted power cuts to happen this winter then?
what expected power cuts?
hmm i'd use a lower breaker on this cuircuit on the grounds that if your overloading it you wan't to know about that before you switch to genny power. If it were a 2KW generator i'd probablly advise using a D10 (e.g. 10A overcurrent but with a short cuircuit trip point high enough that its unlikely to neusense trip on surges)Lectrician said:A little CU fed via a 40amp MCB from the main CU (with changeover switch inbetween) would be best for this, as pluggy says.
andy said:Adam_151 said:so then ban, you expecting the predicted power cuts to happen this winter then?
Adam_151 said:The media from time to time reports we might face an energy shortage this winter...think they predicted that last year as well
Then we would all be nice and warm in the future !*thinks its about time the government realised nuclear is the way forward*
I don't think there's much of a "don't like" aspect as much as efficiency and control - from the efficiency point of view, the engine needs a certain amount of power just to keep itself going, and that's pretty constant, so if you're taking only a light load the percentage of useful work to overhead gets high. You may find (picking figures from the air) that it uses 2l/hr of fuel at 50% load, and 1l/hr on 10% load so it's costing a lot more per kWh on low load.ban-all-sheds said:My only concern is, from advice in Another Place, that they don't like running on a light load. If I do get a 3 - 5kW one, it would spend a lot of time serving a few hundred watts......
Not if I buy this one and flog juice to them...numpty with a crowbar said:But that noise you hear on the cold winter night will be music yo your ears - as your neighbours shiver in the darkness
