Another amateur I\\\'m afraid!!
I have an oil fired boiler (Boulter - Camray Compact) with expansion vessel (BOSF - 18 litres) and pump (Grundfos Type UPS 15-50).
We have just had a largish extension built (for the size of the house) which has 3 brand new radiators. If I turn all the radiators in the house off - and leave the radiators in the extension on - they heat up well. They are lower than the boiler but the furthest away from the boiler.
When I turn on 2 or 3 of the radiators in the house they gradually take heat from the radiators in the extension (until the radiators in the extension are lukewarm).
If I turn all the radiators on - the radiators upstairs are the only ones which work - leaving all the other radiators cold (all downstairs) ...
The pump \\\"seems\\\" to be working (it moves, whirs and gets hot) and the pressure in the system is at 1 bar (just over) ... I have also bled all the radiators until water drips out.. I know the answer is to get a plumber (and I will in due course) ... is there something I ought to be trying to save me the hassle?
