Sharpie
Joined: 02 Oct 2005 Posts: 4 Location: London, United Kingdom Thanked: 0 times
Posted: Sun Oct 02, 2005 3:27 pm Post Subject: Strip light bulb |
I have managed to take the old light tube out and buy a replacement but it is extremely difficult to put the new tube back in the fitting. Apart from using force as an option which seems silly when you are holding a thin tube I can't see anyway around it. The pins at the end of the tube do not seem to want to fit even though they are the same size as the old one!
Help please!
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Sun Oct 02, 2005 3:29 pm Post Subject: |
what exactly seems to be the problem? pins too big? can't get both caps on.
is this an insert and twist fitting or one where you have to spring the caps on. |
Sharpie
Posted: Sun Oct 02, 2005 4:00 pm Post Subject: |
It is a german maker called Thebo
http://www.thebo.net/Thebo2005/PDF/thebo2005.pdf
R2400/18
It does appear to be a twist to put back in as I didn't do that to remove the bulb.
The fittings at the end can be pushed in towards the main fitting but that does seem to help the fact the the pins won't go into the holes.
I should have also said that the pins are the same size! and its Doesn't appear to be a twist fit not does
________________________
moderator
please note 10a which is here |
plugwash
Posted: Sun Oct 02, 2005 4:08 pm Post Subject: |
the normal method is to oush it into one end then pull on the other end and pop it in |
Sharpie
Posted: Sun Oct 02, 2005 4:19 pm Post Subject: |
Finally managed to change it first by taking it down from under the kitchen cabinet and then figured out it was a twist and fit!!
Because I didn't take it out that way it wasn't obvious!!
Thanks!! |
