DIYnot
Local | Network
   DIYnot > Forums
Local | Network
unblocking sludge choked pipework in central heating system
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
sandys
from United Kingdom
PostPosted: Tue Oct 04, 2005 1:37 pm Reply with quote
hot water supply pipe to a radiator is absolutely blocked and no liquid will flow through it. Have checked that the valve at the radiator is not faulty.
Supply pipe lies in a totally inaccessible area. mains pressure will not move the blockage. Is their some way I could apply suction or alternatively are gadgets available which will allow me to drill out the blockage ( like the systems used to unblock drains. The system is heavily contaminated with sludge and eventually will require chemical desludging. I'm told the chemical desludger will not help with this current problem
Back to top
 Alert Moderators
colinand
from United Kingdom
PostPosted: Sat Oct 22, 2005 11:34 pm Reply with quote
I am busy unblocking my microbore pipes. I discovered that the blockage is always near the beginning where the microbore comes off the manifold connected to the larger bore supply pipe. I presume the temperature drops and possibly there's also a stagnant reservoir there. I was able to unsolder the microbore at straight couplings about 20cm from the manifold and poke stiff wires along - bicycle spokes are good. The crust was hard and difficult to dislodge but I managed it eventually. I've replaced the soldered couplings with compression ones so I can do it again if need be though hope this time to keep a better watch on my corrosion inhibitor - the last lot worked for 10 years and even though I have no connection to the mains so couldn't become diluted, it did stop working eventually.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3553 times
PostPosted: Sat Oct 22, 2005 11:55 pm Reply with quote
You can only "suck" to one atmosphere whereas you can apply pressure at many atmospheres.
Only physical intervention is likely to work although mineral acids at high pressures might but would be extremely dangerous!
Tony
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 873 times
PostPosted: Sun Oct 23, 2005 12:23 pm Reply with quote
[quote="Agile"]You can only "suck" to one atmosphere whereas you can apply pressure at many atmospheres.
Back to top
 Alert Moderators
sandys
from United Kingdom
PostPosted: Sun Oct 23, 2005 1:02 pm Reply with quote
Thanks for your suggestions. I appear to have 90 degree bends in the plastic pipework and its there that the gravel, must be ferrous oxide, rather than sludge has gathered. Need to take up a floor or knock a wall down to get at it. Maybe an electric replacement heater would be both cheaper and less aggravation.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1111 times
PostPosted: Sun Oct 23, 2005 1:46 pm Reply with quote
That's what some landlord's decide!
Obvious really but if you apply the mains at the radiator end you stand a better chance of getting something moving. You could also hire a pressure test pump (cheap), and pump up to say 10 bar or whatever you reckon the pipes will stand before she blows, jim.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Unblocking / Flushing Microbore Central Heating System 18 6880 Tue Jan 05, 2010 10:50 pm
DIY drain unblocking warning! 20 18820 Tue Jul 06, 2010 8:11 pm
Bicarbonate of Soda For Unblocking a toilet 5 640 Sun Mar 21, 2010 11:10 am
Unblocking waste disposal unit 6 1840 Thu Jul 01, 2010 10:01 am
Unblocking shower drain 2 40 Mon Sep 05, 2011 3:31 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
