Tricity Bendix AW1400W Faulty Drain Pump and Module
4 Oct 2005
Northamptonshire
The washing machine stopped pumping, when I took the pump off it was very obvious that the pump was burnt out so I purchased a new one but when I fitted it the machine wouldn't work. I removed the Module and again it was obvious that a component on the board had burnt out it was black and charred. I fitted a new module now all the led's flash but nothing else. I acquired a manual but it doesn’t mention if all led's flash what to do
Can anyone help as I've already spent quite a bit so far
on some machines you have to enter a code to tell the board which machine you've fitted it to. i would expect the board literature will explain this, have another read. configuration code is what you're looking for.
Thanks Keithwasherman but there was no literature with the board, maybe the manufacturers don't want us to have this information.
i'm not familiar with your particular machine. can you tell me if your function buttons are laid out horizontally or vertically?
i have a module diagnostics manual, but it does my head in reading it. if you get back to me i'll try to pick out the relevant info for you to try.
it could take a while.
alternatively if you can get manuals it is distriparts publication number
5993508-38.
It has horizontal buttons. The manual you are talking about maybe the one i've got which guides you through the diagnostic cycle but mentions nothing about if all LED's flash simultaneously and this is the problem as soon as I press the start pause and the next button to the left and turn the program dial to the right
from what i can gather (without refering to the manual) the first step of the diagnostics is that all leds should flash. i'll have to look up to find out whats next
Thanks for the help Keithwasherman
but the saga has ended regarding this washer,
I found out that there are four alternative modules for this model and guess what, I had the wrong one.
When I ordered the module there was no option online to enter a product code only a model number. when I entered the model number there was only one module listed which I think is bad.
Anyway thanks again
Johnnyhoz
