DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting mosaic wall tiles
This topic originated from the How to page called Mosaic tiles
Click here to return to the page called Mosaic tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
craigh
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 29, 2003 10:01 am    Post Subject:
Reply with quote Thanks
I have a border around a bathroom for which I want to fit mosaic tiles. The mosaic tiles are supplied on a sheet with appropriate spaces in between each tile. I have tried to use Wickes waterproof tile adhesive to fit the tiles but the mosaic sheet slips out of position each time. Is there an alternative for an instant adhesion?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Aug 29, 2003 11:05 am    Post Subject:
can you not support them with some thing while the adhesive goes off? say a couple of small nails through the gaps at the top or a bit of masking tape across the tiles onto the wall above
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
craigh
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 29, 2003 11:22 am    Post Subject:
tried the supporting with nails but due to the size weight and number of individual tiles per sheet this method didn't work. I'll give the masking tape a go. Cheers icon_smile.gif
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Aug 29, 2003 3:46 pm    Post Subject:
Try using 'Gripfill' tube instead of tile adhesive which is quick drying & stick to anything.You might have to hold the tile for approx 2-3 mins depending the thickness of the adhesive.See this.
Back to top
 Alert Moderators
MrHelpfull
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 16, 2003 2:42 pm    Post Subject:
Wall tiles slip down
To stop the tiles slipping down, fix a batten to the wall, ideally a piece of wood as used in door jams, but anything will do but ensure it is straight!
Once you have ensured this is level, you can fit the tiles onto it without worry and remove it once the adhesive has set.
A word of warning, decide what you want to line the tile up with, setting them exactly level may look wrong if the worktop of floor is not level.
Also remember, start from the middle and work outwards this will give you an equal size cut tile on each end that looks much better.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
mosaic tiles 6 15360 Wed Jun 04, 2003 1:50 pm
granite grit & mosaic tiles 2 5120 Sat Aug 17, 2002 2:12 pm
repairing a mosaic wood floor 2 4300 Mon Jul 08, 2002 11:17 am
Mosaic Floor tiless 3 880 Wed Sep 24, 2003 1:05 pm
Fitting shower screen over border tiles 6 820 Wed Jan 16, 2008 9:37 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
