Morning folks,
About to start adding tongue and groove cladding to the lower half of the bathroom walls as the next part of our never ending house refurbishment once I get the flamin' tiling done - but that's another story..... The walls are fairly flat and if possible I'd like to avoid removing the radiator and was thinking "can I just adhesive the cladding direct to the wall rather than fix horizontal slats every 2 foot and pin the claddinng to that....
Sooooo - can I get away with that?? And If I can what kind of adhesive shouls I be looking at?? Not over happy with pink grip when I've used it in the past - although I guess I can use it again at a push - just seems a bit weak unless you use a load of it.
as I sauid I'm trying to avoid removing / moving / rehanging the radiator if I can so if I can get away with using adhesive that would be a lot more straightforward - is it wise??? I'm also guessing if I'm cutting meter stips of cladding that I can use 3 or 4 dabs of adhesive and that'll hold - again any pointers would be appreciated
