DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Alarm problem (self caused!)
This topic originated from the How to page called Alarm Systems
Click here to return to the page called Alarm Systems.
  View previous topic :: View next topic
Author Message
Mr_Squidge
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 06, 2005 4:12 pm    Post Subject:
Reply with quote Thanks
I have a guardtec alarm that was already in the house when we moved in. I think that it is either a 360 or a 580.
Anyway, I was trying to swap over one of the movement detectors for an \\\'animal smart\\\' one that I had bought - so that the cats would stop setting off the alarm.
Well, you guessed it. I managed to set off the tamper alarm and couldn\\\'t reset the system (no power to the control pad). So I had to get the ladder out and disconnect the battery within the alarm siren box - man that thing is loud when you are that close to it!
The problem that I have now is that there is no power to the control pad so despite re-wiring to the original movement sensor I cannot get the alarm to work.
Any advice would be most welcome.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Oct 06, 2005 6:31 pm    Post Subject:
you have blown a fuse in the panel change it for another one tha is the same as the blown one, probably 1 amp.
also the pet detectors dont work, but then if you have changed the origonal one for a pet detector, assuming its at the same height it will probably pick up nothing, but in geneal they are a waste of time.
try a search for more info
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Thu Oct 06, 2005 7:50 pm    Post Subject:
I have to say my **** cat has not set them off yet, and the system's been installed 6+ years.
Edit:
Oh **** me! That **** Swear Filter has **** bleeped out the word **** ****! I don't **** believe it!
****-b*****d!
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Mr_Squidge
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 07, 2005 5:36 pm    Post Subject:
Thanks. Have found fuse (glass line fuse, like you get in car radios) and it is blown as you suggest. All I need to do now is find somewhere that sells them... I assume the colour banding on it tells me what amp is is?
Hopefully that'll solve the problem.
P.S. So the animal immune sensors are no good then? I suppose I'll find out when I get the alarm back working.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Fri Oct 07, 2005 10:29 pm    Post Subject:
The size is normally etched in the base of the fuse, i.e. F1A (Quickblow 1A) or T1A (Antisurge 1A) etc.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Megger caused motor to explode! 12 760 Sat Oct 11, 2008 1:06 pm
Tripping caused by touching neutral and earth 19 880 Fri Nov 28, 2008 5:39 pm
Damage caused by tv fitter 13 940 Sun Sep 02, 2007 1:55 pm
What Is The Object And What Caused The Hole? 30 1780 Mon Aug 24, 2009 8:54 pm
Testing an RCD on a portable distro caused main RCD to trip 14 600 Mon May 07, 2007 7:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
