Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Sat Oct 08, 2005 4:12 pm Post Subject:
If its just the light you're removing, take the wires out of the light fitting, NOTING WHAT GOES WHERE, and replicate these connections (without the one to the light itself, of course) in a junction box (round thing with holes in the sides) in the loft, NOT CHOC BLOC.
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Sat Oct 08, 2005 4:53 pm Post Subject:
if plastered over and there is a floor above, they should be crimped
Joined: 08 Oct 2005 Posts: 2 Location: London, United Kingdom Thanked: 0 times
Posted: Fri Oct 14, 2005 4:21 pm Post Subject:
Thank you for all your replies. Being a complete amateur I am struggling to understand some of the lingo!
To give a clearer picture the light I want to remove is one of three hanging ceiling lights. I only want two as I intend to use bigger lampshades. Therefore the switch does not need to be removed. As suggested I was hoping to be able to remove the light socket and shove the cable up in the ceiling void and plaster over the hole. It sounds as though this can be done if I 'crimp' the end of the cable, but I don't know what crimping is?!
Lastly, before undertaking this task is it sufficient to switch the electricity off at the mains or do I have to do anything else before taking off the light socket?
Joined: 14 Oct 2005 Posts: 8 Location: Ipswich, United Kingdom Thanked: 0 times
Posted: Fri Oct 14, 2005 4:33 pm Post Subject:
Hi there!
If you have a modern consumer unit (the box with all the fuses in) you can turn off the individual electrical circuits e.g. the lighting circuits.
If not then turn the main power switch off on the consumer unit (usually a large red switch).
In most lighting circuits there are 2 cables for the circuit (one coming in and one going out of the ceiling rose), a switch cable and the light cable. It could possible have one less circuit cable (if it's the end light in the circuit).
You need to turn the power off and remove the ceiling rose cover, report back with how many cables are in the ceiling rose.
Posted: Fri Oct 14, 2005 6:12 pm Post Subject:
If this light is the middle of the 3, then there should be maximum of 2 cables, depending on how it has been wired. Have a look. If there are only 2 cables, simply crimp them together, insulate, and shove them in the roof space. Use a proper ratchet crimper, not the "squeeze and hope" jobs.
However, at the other extreme, there may be up to 5 cables.
Posted: Fri Oct 14, 2005 9:23 pm Post Subject:
and dont turn the switch on either. or bang goes the lights.
Joined: 11 Jan 2004 Posts: 16480 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Fri Oct 14, 2005 11:17 pm Post Subject:
Can you explain this strange comment?
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
Posted: Sat Oct 15, 2005 9:25 am Post Subject:
if there are only 2 cables then 1 will be the switch?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
