DIYnot
Local | Network
   DIYnot > Forums
Local | Network
leaking toilet outlet pipe
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
mondial
from United Kingdom
PostPosted: Sat Oct 08, 2005 2:37 pm Reply with quote
My toilet has a horizontal pipe, straight out of the back of the pan and through the wall. There is a joint in this pipe where the outlet of the pan meets the straight pipe and it is leaking quite badly.
What should I use to seal this and how do I apply it?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Sat Oct 08, 2005 2:47 pm Reply with quote
Might pay you to replace with one of THESE or an offset one. icon_biggrin.gif
Back to top
 Alert Moderators
mondial
from United Kingdom
PostPosted: Sun Oct 09, 2005 11:49 am Reply with quote
Thank you for the suggestion but that will entail removing the toilet pan from the floor, also possibly breaking the soil pipe when I try to remove the leaking Joint. Is it not possible to just seal the existing joint? With What? And, how?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Sun Oct 09, 2005 12:04 pm Reply with quote
You could try silicone for a bodge.
I would do it properly and have done with it. I would think it is leaking beacause it is not seated properly i.e not pushed home or is at an angle.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Toilet overflow/outlet pipe leaking o 2 440 Sat Sep 26, 2009 3:00 pm
Toilet leaking by the outlet pipe 7 780 Tue Aug 07, 2007 7:02 pm
Large cap between toilet outlet and waste pipe 8 1200 Fri Jun 02, 2006 10:21 am
Toilet Leak - replacing outlet pan/pipe 2 340 Mon Aug 17, 2009 12:35 pm
Leak between toilet pan & outlet pipe! 2 500 Thu Oct 02, 2008 12:54 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
