DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Will I need a macerator?
This topic originated from the How to page called Plumbing in kitchen appliances
Click here to return to the page called Plumbing in kitchen appliances.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
mart1n
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 12, 2005 12:56 am    Post Subject:
Reply with quote Thanks
I am moving my kitchen from its current location to where my dinning room is. This is going to put my sink and dishwasher some 18ft away from where the current drain goes through the outside wall. As you can imagine, this means the drain pipe cannot run at much of an angle, so will i need a macerator to help things along? any advice would be much appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Wed Oct 12, 2005 9:22 am    Post Subject:
Can you not make a new hole in the wall lower than existing one to get correct fall.
You will need an anti vac trap as well for that length of pipe run.
Have a good look at all the possibilities as a macerater seems a bit extreme. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
mart1n
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 13, 2005 1:41 am    Post Subject:
Ok, thanks for the advice, I'd rather not spend on a macerator if I can help it. What diameter pipe do you recomend I use? and what would be an acceptable fall rate (mm fall per meter of pipe)?
Thanx in advance.
Back to top
 Alert Moderators
mart1n
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 15, 2005 5:09 am    Post Subject:
Anyone?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Sat Oct 15, 2005 8:23 am    Post Subject:
Use anti vac trap because of the length, 40 mm pipe with a 1 inch fall for every 40 inches. icon_biggrin.gif
__________________
Back to top
 Alert Moderators
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 15, 2005 5:08 pm    Post Subject:
You on commission for anti vac traps Bacho ! Seems to be your standard response !
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Sat Oct 15, 2005 6:42 pm    Post Subject:
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
SANIBEST MACERATOR TOILET(SaniFlo Ltd) 8 480 Fri Feb 20, 2009 2:38 pm
Blocked Macerator Outflow pipe(edited!) 5 740 Wed Mar 11, 2009 8:38 am
Macerator 4 100 Thu Mar 19, 2009 8:57 am
Noisey macerator 2 200 Fri Sep 26, 2008 1:09 pm
McAlpine flexible wc connector to Saniflow macerator? 4 280 Tue Sep 09, 2008 9:39 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
