stonybloke
Joined: 05 Sep 2003 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Fri Sep 05, 2003 8:16 am Post Subject: Door sill replacement |
How do I replace a rotten door sill? The rest of the frame is good and very securely attached to the brickwork. |
masona
Joined: 05 Jan 2003 Posts: 10853 Location: Essex, United Kingdom Thanked: 7 times
Posted: Sat Sep 06, 2003 10:15 am Post Subject: |
Cut 2 saw cut in the middle of the cill approx 4" apart,remove the middle section then see if there's any nail or screw at the bottom of the door frame and remove it if you can,then use a 2" cold chisel in the middle end section of the cill and split it with a hammer to prise it apart.Make sure the bottom of the door frame is not rotted otherwise you're wasting your time.When fitting new cill put dpc under the door cill to prevent rising damp.You might have to cut the tenon on the frame for flush fitting of the new cill.Make thin wedge under cill to tighten up to the door frame then screw + glue etc......... |
stonybloke
Posted: Mon Sep 08, 2003 9:24 am Post Subject: Door sill replacement |
Perfect! Thanks Masona. The old sill is now out and I am preparing the replacement. Hang on a mo! . . How do I glue the new sill in place if I fit a new strip of DPC - won't it just lift off? |
masona
Posted: Mon Sep 08, 2003 10:37 am Post Subject: |
You could staple the dpc with staple gun,then use mastic sealant to cover the staple or instead of dpc use a good wood treatment such as cuprinol, bitumen paint or strip of leading flashing nailed underneath etc. Don't forget to sealed the nail......... |
stonybloke
Posted: Tue Sep 09, 2003 9:32 am Post Subject: Door sill replacement |
Thanks again - I think that bitumen paint may be the answer. A few thick coats then cement on top. When the cement has set, I'll fix the sill in place with a frame adhesive/sealant and hold it with 4 or 5 hammer-in frame screws through pre-drilled holes in the slot for the rain bar. I'm re-using the old plasic rain bar which I can fit in place after the sill is fixed. The new sill is made from Meranti and I am treating it with Sadolin Brush-on Wood Preserver and then finishing with Sikkens Cetol HLS (3 coats) for abrasion resistance. Thanks again for your help - however I will watch this in case you tell me that my plan is doomed . . . . |
masona
