Any suggestion to get access to door interlock switch ...from the top I can't separate the cable & tube from switch with one hand ....any tips ( I wanted to check terminals before ordering)
Thanks for that ....I did think about doing that (but thought I might not get the plastic ring back on again ) .In the event I got the tube off from below and then swiveled up the wiring and got hold of the switch and unplugged it from the top.
Hopefully I'll get the new switch fitted without losing any further flesh from my arm.
