Indesit123 Died
30 Oct 2005
Oxfordshire
has been repaired a various of times but has never been able to be used on boil wash.
Decided to pack it all in last Friday after sighing it just stopped I Took out my washing(machine unlocked as if finished )whilst machine full of water now light works like it should including resetting flash but absolutely :evil: NOTHING happens with the machine non of the programs work HEELP
yes the door locks fine wants you select a program it then unlocks again when it feels it has finished the program althought it has not really finished
What happens when you try ? It will do nothing until it gets enough HOT water. Have you got the hot water supply tap to the machine closed ?
I only have got cold supply and the heater will never get to the 90c it will start to tick over continously Had a repairman out who said that boiling is a waste of time and money and he could do nothing about it as changing "the Brain" did not solve my problem.(apparently he tried I was not there to verify )
