DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
soot stains
This topic originated from the How to page called Smoke and Soot
Click here to return to the page called Smoke and Soot.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
marion479
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 06, 2005 2:37 pm    Post Subject:
soot stains
Reply with quote Thanks
We have a woodburner in a brick fireplace. The brickwork on the front of the chimney is stained with soot (caused when woodburner opened to add more fuel). We have had this fire for 20 years or so and the brickwork is now quite badly stained - any ideas for removing it please?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
oilman
from United Kingdom
Thanked: 7 times
PostPosted: Wed Nov 16, 2005 6:48 am    Post Subject:
I use traffic film remover sold for use with pressure washers. Spray on a dilute solution and and then wash it off. Put a tray and cloths down as it will be WET!
Why does the smoke come out? This could indicate a problem with the flue. It also sounds like you are either not burning the wood properly or the wood is not properly dry. What type of woodburner is it?
Back to top
 Alert Moderators
marion479
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 17, 2005 10:37 pm    Post Subject:
soot stains
Thanks for your reply - I'll give it a try. There's nothing wrong with our woodburner - we always use well seasoned wood - it's just that when the fire is first lit it tends to be a bit smokey till the flue has heated up. Also, we tend to load it from the top so every time new wood is put in, it's a bit smokey. Actually, the stains on our chimney breast are probably more smoke stains than actual soot.
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 7 times
PostPosted: Fri Nov 18, 2005 6:24 am    Post Subject:
What make of stove is it?
Why load it through the top?
Smoke from wood fires is not a good thing to breathe, the smoke is tar vapour.
Back to top
 Alert Moderators
marion479
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 18, 2005 8:23 am    Post Subject:
It's a Vermont Intrepid multifuel stove with airflow control flap at the rear. It is an extremely efficient stove which is designed to load from the front or the top. It is far easier to load larger logs from the top as it has a large opening/cooking area. We have had this fire for over 20 years and it is still as good as new.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Smoke and soot removal 5 1240 Sun Dec 28, 2003 6:05 pm
Removing Soot from 100% Polyester Tablecloth 2 360 Mon Feb 16, 2009 8:34 pm
Soot 2 960 Wed Mar 15, 2006 11:26 am
under arm stains 3 5940 Tue Jul 11, 2006 9:14 pm
STAINS FROM CAT 4 1700 Sun May 21, 2006 6:18 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
