Hello board!
I have a open pumped system with a gloworm ultimate 30FF boiler. HW storage tank, no immersion, motorised T system, Cold storage in the loft with a feeder tank.
I've had a lot of problems - there's a thread called Temper Mental somewhere which basically ended in me getting the gas valve replaced. At the time, the guy said the boiler looked clean inside and the heat exchange looked good. He gave it a once over and it sounded a lot better after he'd been.
There is one problem remaining, that was there sporadically before and has continued.
On turning the heating system on, everything fires up, turns on etc. etc. and the rads get hot within a minute. The boiler, however, cuts out shortly after that. A minute or so later and it will fire up, then cut out again a few minutes after that.
The heating does work and it gets warm -which is a lot better than we had last year!!! But this obviously isn't right and good be improved.
Is this Kettling? Or is there an airlock somewhere that is stopping the pump from doing its job, and the boiler is cutting out as a safety measure?
The pump is working but it doesn't seem to make any difference whether it's on 1, 2 or 3.
Thanks for any input you can give!
Mr. Tickle.
Mr. Tickle.
