DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
extractor flue
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
  View previous topic :: View next topic
Author Message
cherry cleave
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 9:23 am    Post Subject:
extractor flue
Reply with quote Thanks
I would like to know if a cooker hood can be installed and used without an out side flue.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
comms
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 11:06 am    Post Subject:
If the hood is of the charcoal filter type it wont need a flue. If it's a extractor hood type, I would imagine not venting it outside will defeat the object of having that type of hood as everything will be extracted from the kitchen only to be vented back into the kitchen.
Back to top
 Alert Moderators
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 2:32 pm    Post Subject:
Most (decent) extractor hoods allow you to select (via a lever inside) recirculate or extract. If you select recirculate then you will need to fit the appropriate charcoal filter (obviously, otherwise there is no point or benefit) which are normally purchased separately.
Back to top
 Alert Moderators
ConcreteCow
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 5:16 pm    Post Subject:
A personal point of view...
Can I stress that it is always best to extract, not recirculate. Charcoal filters will not get rid of moisture. Having a kitchen at full blast generates a lot of steam/moisture and unless you want that to condense elswhere in the property, then always extract. Also cheaper in the long run, no charcoal filters to replace.
regards,
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon Nov 07, 2005 5:25 pm    Post Subject:
A point to note is that to comply with the building regulations, you must have a form of extraction in the kitchen. Most new builds achieve this by venting the cooker hood outside.
If the hood is on an internal wall, and venting is difficult, a fan is usually put on the external wall, venting to outside, as an extra to the hood. The hood is then fitted as 're-circulating'.
Building regs don't affect minor alterations, but would affect a major renovation or an extension.
You must also ensure the correct air changes per minute to satisfy the regs.
Back to top
 Alert Moderators
comms
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 07, 2005 9:48 pm    Post Subject:
If the hood is on an internal wall you can get flat ducting, that connects to the hood & sits on top of the wall cupboards, this can then be run to an external wall for venting.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Which RCD side for fan flue? 3 380 Fri Sep 09, 2005 7:45 am
150mm bathroom extractor fan? 11 540 Tue Mar 18, 2008 9:13 pm
Electrics for a bathroom extractor fan 6 220 Mon Mar 24, 2008 12:36 pm
Bathroom extractor connected to a SENSOR switch 13 600 Sun Mar 30, 2008 9:26 pm
Shower Room conversion (extractor fan) 4 280 Tue Mar 18, 2008 3:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
