DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Not a blown Fuse?
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
HarryJAllstar
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 11, 2005 12:18 pm    Post Subject:
Not a blown Fuse?
Reply with quote Thanks
Turning on a light last night appeared to have \\\"blown a fuse\\\". But having checked the fuses, nothing is broken.
Yet none of the lights work.
When I turned on the light, a green spark came from the switch and a bang noise.
Any ideas? Time to call a sparky?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Nov 11, 2005 12:38 pm    Post Subject:
Seems odd that a problem at one switch could stop all the lights from working and not result in a fuse blowing.
The fact that you say fuse would indicate that this isn't a recent installation, so the lighting circuit would not run from switch to switch.
Time to turn off the power, remove the switch, and see what's what. Given how cheap they are you might as well buy a replacement for the switch, just in case. Buying a multimeter at the same time would be a good idea, but given that you posted here before even taking a look do you, perhaps, have no knowledge of electrics?
Doing all this is not difficult, but if you don't feel confident then call an electrician.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
HarryJAllstar
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 11, 2005 12:45 pm    Post Subject:
Thanks for replying, and you're correct - little knowledge here.
It's a fuse wire box rather than a new switch style one, mid 70's. A new fuse box is on the list to do, perhaps I'd better re-prioritise that.
Back to top
 Alert Moderators
BJS_Spark
from United Kingdom
Thanked: 1 time
PostPosted: Fri Nov 11, 2005 12:57 pm    Post Subject:
I would check the fuse closely again. With re-wireable fuses it is best to try and remove the fusewire to see if it is broken in the part of the holder where you can't see the wire or near the screw.
__________________
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Nov 11, 2005 1:02 pm    Post Subject:
If you are going to get an electrician in to fix the lights, have him do a PIR (Periodic Inspection Report) at the same time - it'll cost less than having the two things done separately, and you need to do the latter before you have the fusebox replaced, as you need to know what else should be done to the wiring. And if that involves any cable replacement you might like to know that before you do any decoration you have planned rather than after...
__________________
Back to top
 Alert Moderators
1974stephen
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 11, 2005 5:33 pm    Post Subject:
BJS Spark is right, old style rewirable fuses can be blown even though they might look fine. Replace the fuse wire (with the correct type of fuse wire - more than likely 5A - very thin stuff) and replace. I would suspect that this will cure your problem, or blow again straight away if the part of the circuit in fault is still connected via the switch (ie switch is on).
Make sure you turn the main switch off at the fuseboard before removing and replacing the fuse. When these old style fuses go, they can make a fairly spectacular bang and flash!
BAS is also right, and even if this cures your problem, with an old style fuse board a PIR is also very desirable.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Main House fuse blown - what type and size to fit 12 1060 Mon Oct 20, 2008 7:43 am
Blown fuse/MCB on a Wylex box 12 680 Mon Aug 27, 2007 5:42 pm
2 switches, 1 light, 1 blown fuse 7 360 Tue Apr 25, 2006 3:44 pm
no lights upstairs but fuse not blown 5 260 Thu Sep 18, 2008 9:51 pm
fuse blown on washing machine - safe to replace? 9 1400 Thu Dec 14, 2006 2:54 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
