DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Garden lights
This topic originated from the How to page called Extending a ring circuit using existing sockets
Click here to return to the page called Extending a ring circuit using existing sockets.
  View previous topic :: View next topic
Author Message
Fabbo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 12, 2005 1:11 am    Post Subject:
Garden lights
Reply with quote Thanks
Can anyone tell me if its ok or not to add a dedicated feed to wireless pir operated lights (300watt max) from a ring main spur.The feed through to the garden would have a 3amp fused on/off switch . Barring that could the feed be plugged (3amp fuse} directly into the socket (consumer unit has rcd protection} Thanks in advance
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Nov 12, 2005 1:59 am    Post Subject:
spuring off the ring via a fused connection unit IS the way it should be done.
couple of things, use arctic flex to connect to the actual light
point the light down wards so as not to annoy your neighbours
dont mountthe light high up or it WILL annoy the neighbours
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Fabbo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 12, 2005 8:48 am    Post Subject:
Garden Lights
Thank you Breezer for your advice and prompt reply. Want to get it checked for P3 and using armoured underground cable don't want to have to move the feed position if wrong.. Is it a socket off and existnig spur thats a no no?. Out of interest would the same method be correct for a feed from a 4mm sq radial circuit socket as well?. This wireless pir and receiver I've got from screwfix {£40) seems brill.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Garden walkover decking lights 7 380 Wed Jun 25, 2008 9:02 am
Garden lights.... is this safe ? 15 560 Tue Jun 24, 2008 3:58 pm
WIRING LIGHTS OUT IN THE GARDEN 2 360 Mon Aug 14, 2006 9:34 pm
garden lights 3 220 Mon Jun 30, 2008 8:18 pm
Garden Lights 7 440 Thu Apr 06, 2006 7:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
