lino/vinyl
8 Nov 2004
hey guys,
hope you can help, i am thinking of putting some vinyl down in the bathroom, but i am wondering if there is a special technique for cutting it around pedestals toilet etc, my sister had some laid recently and it is cut so accurate i cannot understand how they did it, maybe they apply heat or summat to help bend it in to place
hope you can help
bill
i made a template and used that, at my mum's i took old lino up and used that as a template
billozz said:
hey guys,
hope you can help
bill
Hi
If it is your first time fitting a vinyl floor I suggest you get a big tube of silicone to seal over the less that perfect edge you will get!! Fitting vinyl is fairly skilled to get a neat job.
To cut round the pan and pedestal start by making a series of small cuts that allow the edges of the vinyl to lap up the curved edge.
(Don't try to go all the way or you will cause the vinyl to split)
The trick is to get a hooked stanley blade instead of a straight one, put some pressure against the side of the loo with the blade so the cutting edge is flush, then draw the blade around in a smooth movement. Trying to do it in little bits will leave you with a 'sharks tooth' edge.
You may find you get a nicer result if you can remove the wc and pedestal. Quite often the sink pedestal will just lift out by removing a couple of screws and gently lifting the sink. Some wc pans are easier to remove than others depending how they are fitted to the cistern.
until you have done quite a few of these you are unlikely to get the perfect result you are looking for. If the sanitary ware is white you can use a small bead of white silicone to leave a reasonably tidy finish, if the sanitary ware is coloured use clear silicone.
Ed
www.interiorharmony.co.uk
