DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
wooden floor on battens on concrete?
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
mainoo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 14, 2005 11:57 am    Post Subject:
Reply with quote Thanks
I would like to lay a solid real wood floor in a flat that is concrete with vinyl tiles on top. I need to bury my plumbing and electrical network so my idea was to lay the pipes (insulating the plumbing pipework against heat) and then screw down battens (500mm X 500mm or more if needed to accomodate the space used by the pipes). Then lay the wooden floor on to the battens. The wood will be tongued and grooved oak and will be secret nailed.
What's wrong with this plan?
What is the maximum distance apart the battens should be?
I would like to lay insulation between the battens (to protect against cold - not for noise - I am on the ground floor). Can anyone recommend good insulating material for the environment i have described?
Thanks in advance.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Mon Nov 14, 2005 3:40 pm    Post Subject:
Re: wooden floor on battens on concrete?
Thanks in advance.
Nothing wrong with your plan. Distance between battens would be 35 - 40 cm heart to heart. Use 'hammer-nails' to speed things up.
(We've done the same in one huge area (90 sq m) and hammered around 1900 nails in!)
You could use polystryrone sheets for insulation (btw, you do need it also for sound insulation otherwise everything will sound hollow like a huge guitar icon_biggrin.gif )
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
mainoo
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 14, 2005 4:14 pm    Post Subject:
Thank you very much for your advice.
When you say hammer nail - what do you mean (i'm a novice but i did a search on 'hammer nail' and didn't find anything conclusive)? Is that the same as porta-nail?
Also does anyone know about sprung battens? Someone suggested them and described them as very nice to walk on. i see they are used in indoor courts a lot. would they be appropriate then for inside a home? are they expensive (again i did google sprung battens but came across only a few references to their use in indoor courts and boats and no suppliers).
Thanks again
Back to top
 Alert Moderators
confused 2
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 14, 2005 9:23 pm    Post Subject:
I should use 50mm x 50mm battens if I were you it may make it easier to stand up in the room [unless you have very high cielings]
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue Nov 15, 2005 10:30 am    Post Subject:
Sorry Maino, must be my English;-)
These 'hammer-nails' are in fact screws complete with plug. You drill a hole in the batten and underfloor, place the screw/plug in the hole and hammer it down. Can't find the English name, but I'm sure others will
Sprung battens are indeed very expensive and IMHO a bit over the top for domestic use.
__________________
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 15, 2005 11:05 am    Post Subject:
I think they are called hammer fixings i.e. these, often used for stud work, heart to heart ? do you mean centres ?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue Nov 15, 2005 11:10 am    Post Subject:
Thanks Eddie M, those are the ones I mean.
Heart to heart, or from the centre of one batten to the centre of the next batten icon_biggrin.gif (Don't mean you have a nice discussion with your battens icon_biggrin.gif )
__________________
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 15, 2005 12:50 pm    Post Subject:
Fair enough, I always thought heart to heart was a dodgy 70's detective programme, but then again I think it was actually hart to hart. I don't know so much time, so little to do, at the 'mo!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
loft insulation & cross battens 6 1200 Wed Aug 29, 2007 1:19 pm
battene battens battens 26 3100 Fri Oct 26, 2007 10:08 am
Loft: What size cross battens? 3 1560 Sat Aug 18, 2007 3:19 pm
Cross-battens in the loft, extra strength or extra weight? 3 1260 Wed Feb 13, 2008 9:29 am
Hardwood flooring: Spacings for battens 8 720 Thu Jan 20, 2005 2:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
