Header tank full but not filling up the system!!
15 Nov 2005
Kent
Please help, my header tank is full but it's not filling up the system and I have no hot water or heating :cry:
AHA! Sounds familiar, same problem a couple of years ago. The answer is pretty obvious really. A load of crud in the pipe from the Tank to the system. My was so bad that when I drained the heating system to install a new rad the water in the header tank stayed put!!
Remedy,clean the thing out. Try using a net curtain wire down the feed pipe from the tank, a long one.
Then drain and clean the whole system.
eddie
Depending on what the blockage is, you may need to cut out and replace a section of pipe. The usual blockage point is near where the feed pipe joins the circulation pipes.
Cleared one two days ago by sucking at the vent pipe with a cheap water vac, not for the first time. It can be thick jelly-like gunge.
Sometimes it'll clear by connecting the mains to the feed pipe(shoots crud up the vent)
Sometimes excision is the only solution!
Sometimes excision is the only solution![/quote
drain the header tank and moved some pipe work. Now the fov is not running in the header or f and e. I've put the cold in the hot and ran it but still no hope. The header willing up from the expansion pipe??????
Please help
I drain the header tank and moved some pipe work. Now the fov is not running in the header or f and e. I've put the cold in the hot and ran it but still no hope. The header willing up from the expansion pipe??????
Please help B
