DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Help please!
This topic originated from the How to page called Plumbing in a cistern
Click here to return to the page called Plumbing in a cistern.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Hefner
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 16, 2005 10:08 pm    Post Subject:
Help please!
Reply with quote Thanks
The cold water overflow in my loft is overflowing. I have previously bent the valve arm back to prevent the ball rising as high. The problem has returned and upon checking the cistern the ball in completely submergered. Does this mean that there is a faulty with the ball cock and it simply needs to be replaced?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
oilman
from United Kingdom
Thanked: 7 times
PostPosted: Wed Nov 16, 2005 10:40 pm    Post Subject:
It might do. Then again it might be an internal leak in the hot water cylinder.
Back to top
 Alert Moderators
plumberman_uk
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 20, 2005 11:57 pm    Post Subject:
very likely the washer on the ballvalve has perished...dont try repairing it if the valve looks old.. better replace the lot
Back to top
 Alert Moderators
why me!
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 21, 2005 4:55 pm    Post Subject:
you might want to check the piston valve, if its cracked (it only takes a small hairline fracture to cause a leak) replace it, they're only about £1 or at worst replace the whole ball cock arm mechanism (about a tener)
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
