DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
No power through sockets
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
freeze123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 19, 2005 12:45 pm    Post Subject:
Reply with quote Thanks
HELP...I Have no power going through plug sockets but i have all lights.No trips in fuse box.Can someone help me plz...
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sat Nov 19, 2005 12:55 pm    Post Subject:
Why won't my car start?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Nov 19, 2005 4:45 pm    Post Subject:
Not enough information. Did it happen suddenly? Was anything interesting going on before it happened? Can you switch the MCBs off and on again? Have you recently drilled any holes in walls? How old is your installation, and how well was it done?
Back to top
 Alert Moderators
freeze123
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 19, 2005 4:59 pm    Post Subject:
Just woke up this morning and had no power in sockets.just moved into house so dont know what wireing like.a mate of mine said something about i need to get something tightening in fuse box.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Nov 19, 2005 5:04 pm    Post Subject:
You probably won't be able to safely isolate the consumer unit while you poke about with it it, your mate might well be right, but unless you've got very good life assurance and your wife doesn't like you, best to call out an electrician.
If you've only recently moved in there could be all sorts of dodgy things you don't know about.
It just struck me - if you've got a good quality, very modern installation, you might have an RCD controlling the sockets - this will look a bit like a second main switch in the CU. If your does look modern and good quality, see if it has. It operates rather like those RCD adapters you use with a lawn mower, but bigger, and could havce been tripped by. e.g. a ketttle in poor condition. the RCD will have a "test" button and a "reset" switch. Usually you have a split load with sockets protected and lights not.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Nov 19, 2005 7:02 pm    Post Subject:
When some RCD's trip, the switch only trips half way to off.
This is so you know it has tripped and not been phsically turned off.
It can often look like it is still up when looking from below.
You would need to pull the switch fully down to off, and then back up to on.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Nov 19, 2005 7:11 pm    Post Subject:
did the poster not say "No trips in fuse box" implying there are no mcbs? although i would agree there may be an external rcd
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Nickthedentist
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 19, 2005 9:12 pm    Post Subject:
I interpreted that as meaning that none of the MCBs in the CU had tripped - but you could be right! icon_confused.gif
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sun Nov 20, 2005 9:25 am    Post Subject:
Thats how I read it aswell icon_wink.gif Assuming he thought none had tripped, but the RCD had.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sun Nov 20, 2005 10:01 am    Post Subject:
His silence makes me assume that he's got no power to run his PC!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sun Nov 20, 2005 3:25 pm    Post Subject:
you sorted that yet ban? quite a major problem i'd think especially if you drive to work!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Nov 21, 2005 12:21 am    Post Subject:
lol
__________________
Back to top
 Alert Moderators
dwain dibley
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 21, 2005 7:37 am    Post Subject:
is your car parked near a building?
If so it may need be tested by a part p qualified mechanic (apparently)
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Moving power sockets 17 740 Tue Feb 05, 2008 12:21 pm
spurring off power sockets for lights 3 140 Sun Dec 28, 2008 7:39 pm
Power to Sockets Keeps Tripping 11 300 Sat Aug 01, 2009 6:10 pm
HDMI Cabling and power sockets 17 1060 Thu Jun 15, 2006 1:31 pm
No power in downstairs electric sockets 8 480 Wed Jun 17, 2009 7:58 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
