AEG oven installation
19 Nov 2005
Derby
Howdo geezers,I'm replacing an old gas cooker with a built under electric oven.The only Kw rating I can see is inside oven on label= 3Kw.I\\\'m using 6mm2 cable,a 45amp double pole sw.,and a cooker terminal outlet.Do you think this is overkill for a 3kw oven?
In AEG info it states min cable size 2.5mm2, min fuse 15a, max 20a.
I'm a little confused as there seems to be a lot of talk about connecting via 13 amp plug to ring main socket.Why would AEG not fit a plug to oven rather than a terminal block if it was this easy?
Cheers Corn.
Cheers Corn.
ask AEG, i would guess its to save money on them buying / making plug tops, think about it, plug top, 50p now multiply that by number of ovens @3kw they make, lot of money isnt it?
Maybe you bought the same AEG oven as me. In the brochure it stated 13A and gave the impression a plug would be fitted. However, on receiving it, it has the same requirement as yours.
It's not overkill: someone might want it swapped for a double oven later and thank you for the provision now.
The best advice I had was to use 6mm from the cooker switch to oven via outlet as 6mm was already in place from CU to cooker switch (would be 10mm all the way otherwise). And swap the cooker MCB for a 16A or 20A.
