DIYnot
Local | Network
   DIYnot > Forums
Local | Network
1 cold radiator upstairs - TRV
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
tajl
from United Kingdom
Thanked: 1 time
PostPosted: Sun Nov 20, 2005 8:26 am Reply with quote
1 of my upstairs radiators has suddenly stopped working, and now it's permenantly cold. It has a thermostatic radiator valve (Honeywell) and was working fine until Friday. Now it won't heat up regardless of the setting of the TRV.
The pipes into the TRV are also cold, as well as the outlet pipe. I have tried bleeding the air from the radiator, but there was no air in it to bleed - all that came out was clear water. I also tried turning off all the other upstairs radiators, but it made no difference.
All of the other radiators seem to be working fine.
Is it more likely to be the TRV that's failed or a blockage in the pipe (it is a hard water area). Is there any way to force a stuck TRV to open manually?
The house and entire heating system are 5 years old.
Back to top
The following user says thank you to tajl for this useful post:
kendra (4 Dec 2012)
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Sun Nov 20, 2005 9:57 am Reply with quote
Yes. Do a search on the forum.
Back to top
 Alert Moderators
Bigears
from Ireland
PostPosted: Sat Dec 03, 2005 12:13 pm Reply with quote
Hi
I have exactly the same problem, my TRV is Myson. the trick is to take off the the whole plastic bit , there shold be a ring under the regulator with serrated edges, loosen this and the TRV should come off, you will then see a little pin sticking out of the bottom valve( the bit still attached to the rad), press this down a few times, to unstick it, it worked for me, the problem I have now is when I refit the TRV the radiator goes cold again.
hope this helps
Back to top
 Alert Moderators
tajl
from United Kingdom
Thanked: 1 time
PostPosted: Sat Dec 03, 2005 7:44 pm Reply with quote
Thanks for the advice. I had also managed to work out which bit comes off - it's always the problem when people just say take the top off, you don't know which bit is supposed to come off. As you say, there is a metal knurled collar beneath the plastic top that just unscrews with fingers, then the whole plastic piece comes off. The metal prong that is then exposed needs to be pulled up with pliers (and pushed up and down a few times to loosen it). It's fixed my problem, although it is still sticky, so I've had to give it the pliers treatment a few times. icon_wink.gif
Back to top
 Alert Moderators
chrishutt
Thanked: 20 times
PostPosted: Sat Dec 03, 2005 7:49 pm Reply with quote
No it doesn't! If you read the post on this in the sticky reference topic above you would see that you should not pull the pin out.
Back to top
 Alert Moderators
tajl
from United Kingdom
Thanked: 1 time
PostPosted: Sun Dec 04, 2005 12:51 pm Reply with quote
Not sure what you mean by "no it doesn't". Or how to find the "sticky" forum.
Pulling the pin back up has certainly worked for me. Changing the setting of the valve to cold has the effect of pushing down on the pin. But it is not attached to it, so it can't pull it back up again when you set the valve to hot. Presumably there is some sort of spring that normlly pushes up the pin when you release it by turning the valve setting to hot.
In my case it's clearly been stuck in the down (shut position), and presumably the spring is not quite strong enough to overcome the friction of a stuck pin - particularly when it hasn't been used for a while. The only way to get it to come back up when stuck is to pull it up manually e.g. with pliers. So what's wrong with that?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sun Dec 04, 2005 12:54 pm Reply with quote
Back to top
 Alert Moderators
ct888
from United Kingdom
PostPosted: Mon Jan 04, 2010 3:19 pm Reply with quote
Hi - we have just moved to this house and all the radiators work fine except two upstairs in adjoining rooms that seem to be at the end of the loop. The pipes either side of both are cold and there is no air in the two radiators. They are fitted with thermostats and the inlet valves are open fully. Anyone have any ideas please? If it is an airlock in the pipes, what do I look for to draw off water? Many thanks - I am not a good DIYer! icon_cry.gif
Back to top
 Alert Moderators
kendra
from United Kingdom
PostPosted: Tue Dec 04, 2012 12:11 pm Reply with quote
I have found this sight on searching for a answer to how to release my thermostat valve which was stuck on cold. I have removed the plastic cover and tapped the valve a few times and it released and the radiator is now hot, I am a 64 year old widow so have to do this type of thing myself, but with the help of the original post I did do it myself icon_biggrin.gif
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 883 times
PostPosted: Tue Dec 04, 2012 12:14 pm Reply with quote
Well done you. Merry Christmas.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Bleeding 1 half cold upstairs radiator .. but it sucks in? 8 1760 Tue Nov 11, 2003 10:58 pm
one cold radiator upstairs 6 640 Fri Feb 13, 2009 7:28 pm
One upstairs and one downstairs radiator cold 11 1040 Sun Feb 17, 2008 7:25 pm
Upstairs radiator cold at bottom but hot at top 2 40 Wed Oct 26, 2011 8:42 pm
upstairs radiator cold. 4 1280 Thu Apr 06, 2006 9:29 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
