Hi Im aware changes were made in notifying work under part p in April. Can somebody please give me a link to a site or info on where i can find more information out about the changes please
Notification was not, and is not, anything to do with Part P.
Part P has not changed, and still applies to any work whatsoever on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter which operate at low or extra-low voltage and are—
(a) in or attached to a dwelling;
(b) in the common parts of a building serving one or more dwellings, but excluding power supplies to lifts;
(c) in a building that receives its electricity from a source located within or shared with a dwelling; or
(d) in a garden or in or on land associated with a building where the electricity is from a source located within or shared with a dwelling.
