removing a two way switch???
22 Nov 2005
Hi hope some one can help?! I have old wiring ring lighting and wish to remove one of the switches, as it is one of the ceilig pull down jobs that is no longer used. i have 3c wich i presume goes to the other switch and 2c wich is the ring?? can you please varify what i am about to do just want to check got it right
thanks bean
The 2c is likely the switch wire and the 3c the strapper (between the two switches).
What are you about to do?
I have had a closer look and know i realy don't know what to do next! Could you please give me a run down of what to do. It is not because i am thick i just don't want to get it wrong! i.e can't see elec.
There are just 2 wires?
