DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Solid Wooden Flooring with Electric Heating
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
NODIYHIT
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 22, 2005 4:40 pm    Post Subject:
Reply with quote Thanks
I am contemplating having a solid wooden floor (18mm thick) with electric underfloor heating (DEVImat system) in my living room. However, this little project raises a lot of questions as I do not know anything about wooden flooring.
After searching the net, my questions are as follows:
1. How do you install insulation, DPM and soundproofing if the floor is glued down?
2. If the floor is secretly nailed to the floor what about the DPM and Soundproofing? Does nailing through them not defeat the purpose?
3. Can an 18mm solid floor be floating?
4. What would be the optimum solution in terms of the different layers underneath the floor?
5. Will it be enough to secretly nail the floor to the insulation backer boards if they are glued down?
6. Any good tips/experience in for installing underfloor heating in connection with wooden flooring?
Hope someone has the answer to all the icon_question.gif icon_question.gif icon_question.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Nov 23, 2005 10:38 am    Post Subject:
Ho nodiyhit, welcome
I will try to answer your questions a best as possible
One thing upfront: with underfloor heating it's much better to use Wood-Engineered flooring than solid. WE is much more stable.
1) you don't
2) Nailed to what kind of underfloor? And yes, it will render the DPM useless.
3) Yes, depending on the width of the room and the width of the boards, but once again we recommend Wood-Engineered boards on underfloor heating.
4) Depends on the underfloor heating system and the installation method you're using
5) Don't really understand the question, sorry
6) see here
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
NODIYHIT
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 25, 2005 5:53 pm    Post Subject:
I want to go for solid as I have found a walnut floor (Plank) that I like. I have searched for walnut in WE, but so far I have not had much success as it is either not as good looking as the walnut I have seen or it 2 or 3 strip, which I do not like (It must be plank).
A few other things:
When you answer to question 1 is no, would that then mean that you cannot soundproof a solid floor? or if you can how?
If I understand your answer to my question 2 correct, so will the soundproofing work ok, but the DPM will be useless?
Also by question 5. I mean: Glue down insulation backer boards (5.5 or 10mm thick) on concrete floor and then nail the solid floor to the insulation backer boards. Would this be possible and stable enough?
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sat Nov 26, 2005 9:49 am    Post Subject:
We do do a for underfloor heating suitable full-plank (bevelled) Walnut Engineered board (Prime and Rustic, see here)
The bonding of the wooden floor (solid or WE) directly to the underfloor is your 'sound proofing', you wont have echoing sounds.
For secretly nailing you need 50mm nails to do it properly, so there you go I'm afraid.
There are underfloor heating systems that will allow you to install the wooden flooring directly onto the system, either floating on a subfloor or on battens placed between the underfloor heating.
Hope this helps
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Electric under tile heating 2 380 Fri May 30, 2008 3:50 pm
underfloor electric heating 9 1640 Tue Jan 10, 2006 1:28 pm
Retracktable Electric Timber Loft Ladder 2 220 Tue Nov 04, 2008 11:13 pm
Can't afford underfloor heating. 6 800 Tue Feb 27, 2007 9:59 am
Timber subfloor options for tiling with heating 4 880 Thu Apr 12, 2007 3:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
