Hi, wonder if anyone can help? Just moved into a house with a Biava thermostatic shower (think it's called High Flow), and the water temp is set too cold! I only get tepid showers even though the water in the tank is hot enough. There's a little red button on the tap that I presume you can adjust to make the shower warmer, but anyone know how I can do it? I'm renting the house so I don't want to do anything major, but I can probably get to the back of the unit with a bit of luck. Someone suggested I could do it with a long allen key, but I'm not sure where or what....and do you have to fix the temperature, or can the red safety button be permanently diabled?
Would really appreciate it if anyone can help...brrrrr! (cold girl shivering)
