how to repair cut TV ariel cable??
20 Jan 2003
moved into my new house, and noticed when i connected the TV to the ariel there was no picture, i thought what the hell i have sky i can watch the channels through that,
however when i was in the loft i noticed the ariel cable had been cut in half by the pervious owner,
my question is what is the easiest way to repair this?
i have tried to connect the two sections of wire with the connectors you noramlly get with a ariel cable kit, but this has not helped.
Use a male and female coax plug to do the joint (or two males with an adapter.)
Not helped ? in what way ? no change ? Are you sure this cut wire is feeding your socket and there is an ariel on the other end of it ?
Have you made good connections on your repair i.e. the coaxial sheaths are connected together, the signal wires are connected and not touching the sheathing ?
as far as i know all connections are fine,
i do get a picture but it is bad
maybe the signal wasn't that good to start with? or the aerial isn't positioned correctly?
You will get some signal loss with every cut and connect. It's possible the previous user had something connected in there - a bigger aerial, or an amplifier. Can you see the aerial at the end of the second piece of co-ax, and does it look modern, and quite big? You may need to tinker with its direction. Are you in a big town, a rural area, or near hills?
It may be the cable was cut to add a booster into the line due to poor signal, previous owners tend to forget about them until moving day and chop them out instead of unwiring in the rush to get out... :confused:
