Hi
Having been let down by local plumber who said I needed a new 3 way zone vlave I have fitted the valve myself. Having drained the small bore system with the rads isolated at both ends, fitting the zone valve and checking all connections the system did not seem to refill. I attempted to back feed the sytem by connecteing cold supply to the rad where I drained the system and rads seemed to fill and eventually I had water feeding into the header tank. Then shuting off supply and starting the boiler the hot water is OK but the rads do not heat properly. 2 out of 4 upstairs get warm, 1 of 3 downstairs gets hot, one gets luke warm, one nothing.
Could this all be a problem with the pump?
The pump is turning, and the zone valve operates according to the control.
Help would be appreciated.
