DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
SPUR for 2 PCs
This topic originated from the How to page called Adding a spur to a ring circuit from a junction box
Click here to return to the page called Adding a spur to a ring circuit from a junction box.
  View previous topic :: View next topic
Author Message
Beanobracknell
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 27, 2005 12:50 pm    Post Subject:
SPUR for 2 PCs
Reply with quote Thanks
A friend is presently running 2 PCs with monitors & speaker amps off a single mains socket using extensions leads.
Should he fit a spur? He would need say 6 to 8 sockets, and presumably should have a single or double socket at the end of his spur on the wall, then use extensions to get his multiple sockets. Is this acceptable for one spur?
Should there be a fuse box where the spur joins the ring mains?
And for future reference, how much currect would a modern PC and monitor draw?
Thanks in advance.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
slippyr4
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 27, 2005 1:33 pm    Post Subject:
Re: SPUR for 2 PCs
Thanks in advance.
It's fine. Each PC+Monitor+Speakers probably pulls less than 3 amps. The plug in extension leads are protected by a fuse in the plug, the worst that could happen is that fuse blow.
Back to top
 Alert Moderators
pdcelec
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 27, 2005 3:23 pm    Post Subject:
You also need to ensure that the earth leakage current is low enough as to not cause a danger as per Section 607 of BS7671.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
lighting spur from a ring main/socket 25 5820 Sun Dec 02, 2007 10:22 am
Installation of new spur. 2 140 Sun Dec 02, 2007 8:11 pm
Lighting & Fan Spur 2 220 Tue Nov 27, 2007 11:48 pm
Fused spur/ socket/ switched socket 6 640 Mon Nov 26, 2007 9:11 pm
Adding a socket to an existing spur 5 500 Mon Nov 26, 2007 4:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
