End-of-Run Lights Controlled by (1) single pole switch
mts
28 Nov 2005
I\\\'m wiring the lighting in my garage and have 3 lights in a roll on the left and 3 lights in a roll on the right hand side of the garage. Each set of 3 lights is controlled by (1) single pole switch. I\\\'m running 14-2 wiring(black, white & ground) and need a diagram from power source to switch and then from switch to the 1st light which connects to the 2nd, which connects to the 3rd. Can you help?
1: you should be posting in the electrics outside the uk diagram
2: you shouldn't be doing electrics with a painting by numbers attitude, with some basic electrical theory this should be obvious!
Seconded - rules, regulations and cable colours may vary, but as someone once observed, ye cannae change the laws of physics.
If you knew enough about electrics to be able to do this safely you wouldn't need to ask such basic questions.
Click Me
