Hi Guys
Looking for a heads up on this problem with the 54 plate Bus , Recently the Anti-pollution warning has come up , causing the Engine to gom into limp mode , if I switch off and restart it , it usually clears , The Car has done 106k , and is generally in good condition , it gets all sorts of trips ie Town and good runs on the Motorway
Is there a reservoir that pumps a fluid into the Sensor to clean it , I`m sure I have read that somewhere , if there is , is it feasible/possible to replenish the Reservoir with the Fluid as required ?? or is it a Garage job ?
Cheers
Lucky
Cheers
Lucky
