DIYnot
Local | Network
   DIYnot > Forums
Local | Network
BAXI 130HE problem...
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Royston Vasey
from United Kingdom
PostPosted: Tue Nov 29, 2005 10:13 am Reply with quote
It's only a year old and it's started playing up.
When the central heating is on, if you switch a hot water tap on, it's failing to cut over to the hot water - it tries about 3 or 4 times then registers a fault "LO" which according to the manual is "ignition" After resetting the central heating eventually kicks back in but the hot water problem is still there.
Any ideas - is this owt to do with the diverter?
Back to top
 Alert Moderators
Royston Vasey
from United Kingdom
PostPosted: Tue Nov 29, 2005 3:31 pm Reply with quote
I've had a plumber round this afternoon and of course it works perfectly for him and he can't find a fault .....10 mins after he left I'm hitting the reset button...........arrrrrggghhhhh!!!!!!!
Back to top
 Alert Moderators
gazthepottertonengineer
from United Kingdom
Thanked: 126 times
PostPosted: Tue Nov 29, 2005 7:46 pm Reply with quote
the sort of things i would be checking would be gas valve pressures and electrodes icon_confused.gif
Back to top
 Alert Moderators
Royston Vasey
from United Kingdom
PostPosted: Wed Nov 30, 2005 10:45 am Reply with quote
Cheers for that - mate who's a plumber said the same.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Problem with Baxi 130HE Combi Boiler 4 1000 Thu Feb 16, 2006 7:07 pm
Baxi 130HE anticycle CH problem (only works after DHW run) 8 100 Mon Oct 24, 2011 8:46 am
BAXI 130HE - high pressure reading. 4 380 Mon Mar 02, 2009 3:20 pm
Another Baxi Solo Overheat Problem! 3 120 Tue Mar 27, 2012 6:07 pm
Baxi 105e Flue problem 3 320 Wed Aug 13, 2008 10:30 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
