Evening all -
Apologies if this is a daft question - but how am I supposed to introduce a corrosion inhibitor into a sealed (ie pressurised) central heating system...? Clearly in a vented system I'd add it to the header tank... but.... ? Is there usually some point on the boiler at which I can add it...? Don't much fancy squirting it through the bleed valve of a radiator ! My Mum has an 8mm microbore system and I need to change a leaky valve for her... and as I understand it an inhibitor is pretty much essential in such narrow pipework.
Thanks in advance. Kind Regards - Chris.
