hotpoint aquarius extra WD63 washer dryer not drying
Status
Not open for further replies.
1 Dec 2005
Cornwall
my machine will not switch on to dry,the light comes on but no action, i can hear the relay click when choosing the drying programme then soon after the light goes out on th front of the machine again. the drum doesn\\\'t even begin to spin. there is no blockage in the filter. maybe this is a problem with the programming. can anyone help
Percy Vere said:
Have you checked the drier side filter? That could be blocked up with fluff from the clothes.
HI percy, I dont know where to find the filter for the dryer side. There is one filter below the drum, but this for the water drain. Is there another filter?
I'm not familiar with this w/drier but, there should be a filter between the drum and the exhaust hose for the hot air is. Check the end of this hose with the m/c in a drying cycle - you should have hot moist air coming out of it.
______________________________
lynda, moderator
Please note forum rule 20
Status
