My new ceiling fitting only has L, N and E. I have 3 reds, 3 blacks (1 which is the live switch) and 3 earths. Do the reds or the live switch go in L? And where does the other go?
switch live to L on your fitting. Or the brown wire.
You need to connect all the reds together but keep them separate from anything else. Another connecter block will be required if your new fitting hasn't got a spare.
