DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
kitchen units lighting
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
hammerman
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 11, 2003 2:57 pm    Post Subject:
Reply with quote Thanks
Just fitted a new kitchen and we want to put lights under the wall unit. What is the best way to do this. We want the lights to come on when the ceiling light is switched on.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Oct 11, 2003 3:16 pm    Post Subject:
you will need to run a cable from your new kitchen lights to your existing ceiling light. you should then connect the cable across the same two wires that feed your actual ceiling light.
you should use 1mm twin and earth cable
How ever, i think you will regret doing it as you intend, suppose after a while you do not like it, bit alkward to change it then isnt it?
why not put a switch in series with the new lights and wire it from the feed to the light on the ceiling. you could put the new switch next to the new lights under the cupboard.
At night you could just leave these lights on instead of lighting the whole kitchen. better to do it now than decide you want it later.
make a note / drawing first of what cables you have in your ceiling light then post back what you find
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
spark
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 12, 2003 9:29 am    Post Subject:
.....or you could run a 3-core down from the ceiling light carrying a switch-live, permanant-live and neutral. that way you could switch it on and off with the ceiling light now and if you change your mind later, just do as breezer said and connect a switch up in-line. Why did you fit the kitchen and then consider fitting the under unit lights icon_question.gif icon_rolleyes.gif , the number of people I upset by telling them I'll be trashing their freshly plastered wall and newly fitted kitchen to fit flush cables.... icon_rolleyes.gif icon_lol.gif
__________________
YEEE! HAAA!
Back to top
 Alert Moderators
il78
from Vatican City State
Thanked: 0 times
PostPosted: Sun Oct 12, 2003 9:23 pm    Post Subject:
I know its not what you have ask for....but you could always put a switched fuse spur next to a socket outlet and run the under cupboard from this........little bit easier.....less hassle......just another option.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Oct 13, 2003 8:32 am    Post Subject:
If it were me I'd install a double wall switch in place of the single one you have which controls the existing ceiling lights, and have the ceiling and wall-unit lights independently switched.
Then you'd be able to turn them all on or off at once with a single two-fingered operation, or have either one on without the other. Best of all possible worlds.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Oct 13, 2003 9:11 am    Post Subject:
Sometimes you just can't win.
Cue for a non-DIY disaster story (well, not really disaster, but an amusing opposite of Spark's plaster-trashing.)
A friend of mine was once having a kitchen extension built, and when he got home from work on the day the plasterer had been he went to look at the work that had been done. Something seemed wrong. It took him a few minutes to realise that the plasterer had buried all of the socket boxes which had already been installed icon_rolleyes.gif .
Back to top
 Alert Moderators
spark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 13, 2003 5:07 pm    Post Subject:
Sounds familiar, usually either that or dryliners cover everything up icon_rolleyes.gif
__________________
YEEE! HAAA!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Plinth LED Lighting for Low Level Kitchen Units 21 640 Tue May 19, 2009 12:05 pm
Sockets in kitchen units 4 540 Thu Sep 07, 2006 5:35 pm
lights under kitchen units 6 2640 Mon Nov 29, 2004 8:36 pm
Switched Fused connection units and kitchen appliances. 7 780 Sun Aug 10, 2008 2:27 pm
Fitting downlights under kitchen units 4 880 Mon Feb 26, 2007 9:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
