Joined: 12 Oct 2003 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Sun Oct 12, 2003 6:46 pm Post Subject:
converting Australian plugs to UK
Does anyone know how to convert appliances with an Australian plug to UK plugs - in particular those which come with manufacturer fitted plugs (ie can't unscrew them). Thanks
Joined: 19 Apr 2003 Posts: 550 Location: Durham, United Kingdom Thanked: 2 times
Posted: Tue Oct 14, 2003 5:33 pm Post Subject:
You can just replace the plug but be aware that some plugs now have RFI components ( basically an R.F. Filter ) built into them and replacing with a standard plug removes these components. They will work but may cause interfeance to T.V. and radio Etc.
Posted: Wed Oct 15, 2003 4:36 pm Post Subject:
another questin
Thanks for the replies.
Have cut the cord and there are only two colours - blue and brown (ie no earth wire). I presume I just fit these two and hope it will work without the earth wire? The old aussie plug only had 2 prongs instead of the usual three.
Posted: Wed Oct 15, 2003 5:01 pm Post Subject:
thats right brown - live , Blue - neutral
by the way what equipment is the offending plug connected to?
Just a thought.. I was in OZ for a few years and at that time all appliances had a moulded plug on. In Queensland where I was a person had to have a special licence to BUY let alone fit a replacement plug.
I have a Tradesman Radio certificate but even so could not legally fit a mains plug
Joined: 27 Aug 2003 Posts: 21984 Location: London, United Kingdom Thanked: 78 times
Posted: Wed Oct 15, 2003 7:10 pm Post Subject:
I worked once in a small electronics prototyping lab.
I was allowed to work on mains powered equipment, including VDUs wherin you find 10's of KV, stuff with motors and sharp wirlygig finger manglers and so on.
But the day the fuse in my soldering iron went and I replaced it I nearly caused a strike - mustn't do that, sunshine, that's an electricians job.....
Posted: Fri Oct 17, 2003 9:21 pm Post Subject:
aussie plugs
ah yes... every aussie plug I've seen is moulded and don't have fuses (which is why you always end up blowing a fuse and losing power if you have too many things going at once... all foreign to a woman let alone being 'allowed' to do it!).
btw - It's connected to a lamp.
Thanks again
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
