potterton prima wont fire up
6 Dec 2005
Hertfordshire
i have a prima f that will only fire up if you tap the front when it is trying to ignite once it is runing it works ok on constant but not on timer it sounds like a sticking solonoid any thoughts :idea:
Potty only work 8-5, we work round the clock! Its 0122 now.
Your boiler is a simple little thing that just provides heated water.
Your control system uses that water to heat the rads, heat the water cylinder or both.
It sounds as if its a problem with your control system and the boiler itself is OK!
Tony
