DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
bathroom basin
This topic originated from the How to page called Installing a bathroom sink
Click here to return to the page called Installing a bathroom sink.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jfk503
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 08, 2005 10:55 am    Post Subject:
bathroom basin
Reply with quote Thanks
I installed a new mixer tap in my ensuite basin, the connections were 10mm tap tails to 15mm hot & cold connections. I also put in 2 x 15mm service valves, problem is the water flow is now not so good as before.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Thu Dec 08, 2005 10:58 am    Post Subject:
You cant get a quart out of a pint pot.
You have reduced the pipe Dia. so you have reduced flow.
Back to top
 Alert Moderators
jfk503
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 08, 2005 11:18 am    Post Subject:
Thanks for the reply, I kinda thought that was the problem but just wanted to make sure
Back to top
 Alert Moderators
stanrog
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 08, 2005 11:24 am    Post Subject:
Easiest solution - Replace the 10mm tails with flexible tap connection tails , 12mm are available from screwfix.
On reflection this may not work as the screw connection to the tap may not fit, I was assuming they were a universal size but this may not be so.
I replaced my tap tails with flexible hose but took the tails to the plumbers merchants to check i was getting the right screw connection size.
Back to top
 Alert Moderators
jfk503
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 08, 2005 7:25 pm    Post Subject:
Unfortunately the 10mm tails are screwed in but thanks for advice
Back to top
 Alert Moderators
MOO1
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 11, 2007 9:31 pm    Post Subject:
pipe diameter/water flow
[quote="Diyisfun"]You cant get a quart out of a pint pot.
Surely you have to take pressure into consideration. I heard of French plumbers pogressively reducing pipe diameter the further the pipe got from the mains, to maintain water-pressure.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Sat May 12, 2007 7:41 am    Post Subject:
First thing is to have a look at what it says on the box - Are the taps designed for the water pressure range you have available?
Taps designed for use on mains pressure systems will give poor performance on a gravity system, as the waterways through the tap body are smaller.
Mains pressure feeds are at whatever pressure the water company sees fit, but usually 2 Bar or more. Gravity systems usually supply about 0.1 to 0.5 Bar depending on the cold water cistern location.
Increasing the diameter of the tails may improve things a bit, but there's no guarantees...
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replacement Bathroom Basin or Vanity Unit 6 760 Mon Apr 25, 2005 10:10 am
leek under basin bathroom 4 3620 Sun Aug 05, 2007 2:15 pm
New bathroom basin tap 6 120 Tue Jun 23, 2009 8:53 pm
Bathroom basin fixing to drill damaged wall... 4 680 Tue Oct 02, 2007 11:38 am
Noisy pipes whehn bathroom basin taps turned on 2 1100 Mon Apr 24, 2006 2:48 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
