Neil182
Joined: 09 Dec 2005 Posts: 4 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Fri Dec 09, 2005 7:21 pm Post Subject: Float Valve |
I need to replace the float valve in my cold water tank, as it is regularily overflowing. the existing valve is the BS1212 Part 1 type. Should I replace this with the same or a Part 2? I'm a bit confused because both types are still available.
Thanks! |
stanrog
Joined: 02 Nov 2005 Posts: 20 Location: United Kingdom Thanked: 0 times
Posted: Fri Dec 09, 2005 8:47 pm Post Subject: |
Was curious to know what the difference was between Part 1 and Part 2, thus looked it up. You could use either but I would replace with Part 1. |
Bahco
Joined: 08 Feb 2004 Posts: 6462 Location: Wolverhampton, United Kingdom Thanked: 5 times
pf_mills
Joined: 29 Nov 2005 Posts: 32 Location: Kent, United Kingdom Thanked: 0 times
Bahco
Nige F
Joined: 28 Jun 2005 Posts: 7496 Location: United Kingdom Thanked: 32 times
