DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ancient Brittany II Water Heater wont light
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
cole1
from United Kingdom
PostPosted: Fri Dec 09, 2005 7:41 pm Reply with quote
Hi ....My wife has been washing up with cold water for months.....we only have showers now, but its getting silly now.
We have this silly old Brittany II water heater supplying hot water to the kitchen sink & bathroom on one floor - This is the problem!!! It simply wont light....the pilot is on & I've twiddled, screwed - unscrewed most bits on it but it still refuses to light...
There isn't much to it ....just the Heat exchanger & 1 set of valve gear..
I cant see any obvious fault, but I aint a plumber!!...I am about to submit to a repalcement but am reluctant because
...we have this Brittany thing for the Kitch & bath on 1st floor... Then we have a Vailant combi for the central Heating & hot water downstairs in the original kitchen that also powers the central heating throughout the ground floor............* another Stelrad Ideal NF30 serving the central heating on 1st & 2nd floors!!..what a mess...even explaining is chaotic Ggrooooannn!!!
I am gonna post this & see if any of you could advise me what to do? & I'll write a clearer description of the whole picture of our heating conundrum...Please reply soon its getting pretty cold in Kent Brrrr
Regards & Thanks Cole1
Back to top
 Alert Moderators
cole1
from United Kingdom
PostPosted: Fri Dec 09, 2005 7:51 pm Reply with quote
Right.So I bought this 3 Storey Terrace House about 4 years ago....... It has previously been split into two flats & also let as bedsits in the past.... The result is....
Ground floor: Vailant Combi - Supplys Grd Flr kitchen hot water & Grd flr Central Heating (
This works but loses pressure & also wont switch to Hot Water although the rads stay hot if I keep repressurising it intermittently - Suspected faulty Diverter Valve?) ANy advice?
First Floor: Brittany II Water Heater - Supplying 1st flr bathroom & kitchen hot water only (Wont Light - See previous Post)
First & Second floor: Central Heating supplied by Stelrad Ideal NF30 - Central Heating only on 1st & 2nd floors (No Probs, I have been advised that this is the best out of the 2 Boilers) Is it a Combi & could it serve the 3 floors water & heating from its location on 1st floor?
I hope I have clarrified & not muddied the waters further....Absolutely any replies would be SOooooo Appreciated
Cole1
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Fri Dec 09, 2005 8:40 pm Reply with quote
Britony II problem is failed diaphragm - easy to replace.
As for the Vaillant, you need to find where it's losing water - check the discharge pipe from the PRV. Do a search of the forum for more info.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
brittany combi se 80 with intermittent hot water 3 180 Mon Mar 15, 2010 9:48 am
Brittany Combi SE80 No Hot Water PLEASE HELP!!!! 6 920 Sat Jan 23, 2010 6:27 pm
problem with brittany combi se 2 260 Fri Dec 11, 2009 9:15 pm
The dreaded Brittany Combi.............help needed 17 380 Tue Mar 15, 2011 11:09 am
Chefforeaux - Brittany combi SE Problems 4 40 Fri Oct 19, 2012 8:23 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
