john_w_w
Joined: 10 Dec 2005 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Sat Dec 10, 2005 8:29 am Post Subject: Dry lining boxes |
When fitting dry lining socket boxes, should they be fitted before or after plastering/tiling? |
Har_vey
Joined: 16 Nov 2005 Posts: 146 Location: United Kingdom Thanked: 0 times
Posted: Sat Dec 10, 2005 9:46 am Post Subject: |
I'd fit them after plastering because those spring clips don't work very well after you have smacked them to get rid of the massive amounts of spare plaster that your man leaves in the box. Best leave them till after. They can be cut in neat enough then anyway.
Not sure I would want to fit them after the tiler to be honest! Although, can be done.
Can be fitted before or after I would imagine. Personal preference? |
Lectrician
Joined: 18 Jul 2004 Posts: 5166 Location: Devon, United Kingdom Thanked: 20 times
Posted: Sat Dec 10, 2005 9:57 am Post Subject: |
I always fit them prior - when I have to (always prefer metal and noggin).
The small front lip of the box is designed to fit flush to the plaster. Agree, plasterers can go OTT, although on a standard plasterboard wall, it's only a light skim. |
nstreet
Joined: 22 Nov 2003 Posts: 1761 Location: United Kingdom Thanked: 0 times
Posted: Sat Dec 10, 2005 3:27 pm Post Subject: |
Fit prior and fill with newspaper to stop too much plaster entering the box, you can also put masking tap around the front lip, that way when it peels off it removes the excess plaster. They are desinged so that when the wall is skimmed you get a flush finish, otherwise the box stands proud a few mm. |
john_w_w
Posted: Mon Dec 12, 2005 4:48 pm Post Subject: |
Thanks for the advice, I'll fit prior to plastering as suggested. |
