DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Moving rad - depressurising system?
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jeebee
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 12, 2005 12:19 pm    Post Subject:
Reply with quote Thanks
Hello,
I'm currently renewing my kitchen and need to move a radiator from one wall to another. My system is a sealed system - condesing boiler, pressure vessel, all rads on trv's and joined by 8mm microbore. I've read the other threads on this forum and understand that the following procedure will be required:
- Close all valves on all rads.
- Remove rad fitting new valves to avoid water loss.
- depressurise sytem.
- extend pipework to new rad location and connect to rad (one side at a time to avoid water loss).
- open rad valves and repressurise system using filling loop
I'm quite happy with rerouting/connecting the new pipes and valves etc but feeling like a bit of a dufus as I can't seem to work out how to depressurise the sytem, I can find the pressure relief valve but know I'm not supposed to touch this, but can't seem to find any other valves that would appear to release the pressure. Help please, it's a pain to be stuck on what I assume is one of the 'easy' bits.
thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
meldrew's_mate
from British Virgin Islands
Thanked: 0 times
PostPosted: Mon Dec 12, 2005 1:37 pm    Post Subject:
Sound like you have a "regular" boiler with external pressurisation kit rather than a "system" boiler with all the bits built in.
Firstly find the draining point (hosepipe connection), usually at a system lowpoint, or a modified rad valve with hose connection built-in. This is the preferred method for draining/depressurising. As a last resort and if there isn't a drain point use the safety relief valve, this has a red knob which can be twisted by hand to test its operation, usually located close to the filling loop and expansion vessel; it discharges directly to outside so watch out if it can cause damage or nuisance when you open it.
Bleed all rads of air before shutting all flow and return valves (mark their positions for ease of balancing later). Shut all auto air bleed valves.
Next drain water to depressurise the system, probably no more than a couple of litres using the hose point, though as a last resort use the safety valve, remembering to "snap" it shut so it is less likely to leak later.
icon_idea.gif When connecting to microbore make sure the cut ends are square and clean by using a file or de-burring tool; it's easy to make a 6mm hole into a 4mm one just by leaving it "as cut", and go easy with the solder / don't swing on the spanners for the same reason.
__________________
I'm a born again virgin...does the strain show??
Back to top
 Alert Moderators
jeebee
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 14, 2005 12:03 pm    Post Subject:
Thanks for that, can't seem to find any sign of a hose point to release the pressure (unless it's under the floor - likely?) so I suppose will have to use the safety relief valve. Thanks for your speedy reply.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Using 8mm microbre and moving radiator on combi system 2 200 Tue Jul 21, 2009 6:33 am
Moving Radiator - Combi System 5 9920 Tue Jun 20, 2006 8:11 am
moving mains water from one room to another 2 120 Thu Feb 14, 2008 9:44 am
Vokera boiler hot water activation arm stopped moving 6 300 Sat Mar 01, 2008 9:09 am
Moving a radiator.. 7 320 Thu Mar 06, 2008 3:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
