DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Potterton Suprima tripping out
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Goto page 1, 2, 3, 4, 5, 6, 7  Next
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating
  Bookmark and Share View previous topic :: View next topic
Author Message
RobD
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 16, 2003 12:10 pm    Post Subject:
Reply with quote Thanks
My boiler keeps tripping out. About once every day or two it goes into standby mode (red light flashing) and refuses to do anything untill the reset button is pressed.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 9 times
PostPosted: Thu Oct 16, 2003 6:39 pm    Post Subject:
all sorts of things, what type of boiler have you what make, what type of sytem, more information
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Thu Oct 16, 2003 10:26 pm    Post Subject:
There are a lot of posts on the Suprima mate. Chances are it is your PCB that needs replacing but I would recommend you contact a potterton approved engineer and get them to fault find it mate before you do owt
Breezer is right could be a lot of things so get someone to check it out
Back to top
 Alert Moderators
RobD
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 17, 2003 7:21 am    Post Subject:
I did get a corgi bloke out but he said he didnt know what it was cos it was an intermittent fault.
The manual says red light flashing is 'Lockout' but that's all. It also goes into red light flashing mode when the overheat sensor works. However, it sometimes wont reset even when its cold.
Main temperature sensor perhaps??
Dont want to replace the PCB if its something cheaper.
btw its a potterton suprima 50
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 25 times
PostPosted: Fri Oct 17, 2003 5:46 pm    Post Subject:
no more help can I give ( all yoda there icon_lol.gif )
seriously mate without locking horns with your boiler with a multi meter there is not a lot i can say sorry
some of the others may have owt to say
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 31 times
PostPosted: Fri Oct 17, 2003 10:08 pm    Post Subject:
Most of the components can be checked with a meter.
Air pressure switch, overheat stat, boiler stat, gas valve solinoids but if the fault is intermittent it's highly likley it is caused by poor soldered joints on the back of the pcb.
Remove all power to the boiler and remove the plug in terminals and four screws holding the pcb in place.
You may need to use a magnifying glass to examine the soldering especially where the plug in terminals are soldered.
Options are.
(a) re solder the poor joints
(b) replace with a reconditioned pcb £45
(c) replace with a new pcb £135
If you do a search for 'suprima' you will find considerable information on this very same problem
Back to top
 Alert Moderators
harrylad
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 19, 2003 4:35 pm    Post Subject:
Hi folks
Where is the cheapest place to buy the pcb for the potterton suprima? Also is it worth gettin the reconditioned pcb or will it die on me soon?
thanks
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 31 times
PostPosted: Sun Oct 19, 2003 5:54 pm    Post Subject:
you can get your new pcb from www.curzoncare.co.uk about £134 trade.
Potterton introduced a improved version about 18 months ago.
Back to top
 Alert Moderators
Giffordr
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 11, 2003 5:51 pm    Post Subject:
Re: Potterton Suprima tripping out
Rob, did you get this one sorted? I have the same problem and assume is the temp sensor but haven't had it checked yet
Back to top
 Alert Moderators
Giffordr
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 11, 2003 5:52 pm    Post Subject:
Back to top
 Alert Moderators
flashbang
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 11, 2003 6:03 pm    Post Subject:
I had exactly the same problem with my Suprima 60L. Thanks to the advice I got from this forum, I removed and checked the PCB. Examining the soldered joints with a magnifying glass I found a LOT of seriously dodgy joints. Having resoldered them and refitted the board, it has not given me a problem since (Nearly two weeks now) It was tripping out up to three times a day... The whole job took me about 35-40 minutes from start to finish.
I have no idea how fragile the PCB is, but I took care to handle only the edges of the board, and made sure I had no static charge before I commenced work. I know a lot of modern PCB's will blow if you look at 'em.... So TAKE CARE...
Comfortable and warm Flashbang..
Back to top
 Alert Moderators
AL
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 12, 2003 1:18 pm    Post Subject:
Me too, had the same problem suprima 50. Did the same reflowed all the main solder joints (had hairline craks barely visable) and it's worked fine ever since icon_wink.gif All thanks to this forum. Saved me loads of money icon_smile.gif
AL
ps remember to make a note of where all the wires go before you take the pcb out! as well as isolating the mains supply! Saftey first!
Back to top
 Alert Moderators
Julian Cooke
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 19, 2003 12:43 pm    Post Subject:
After 5 years , my Suprima 70 is doing the 'lockout' . I have had the PCB replaced twice recently as well as the overheat thermostat but still same. It's been suggested I should have the pump over-run wired in, but it has been OK without it for 5 years and it only 'locks out' when cold - never when heating is on.
Could pump over run cure it? I can't comprehend why it should!
Julian
Back to top
 Alert Moderators
ashten
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 10, 2004 12:39 pm    Post Subject:
Suprima 100 Lockout Problems - Help and also a question
Hi the same problem has been plaguing us too.
First of all replacement of the Thermistor did the trick £8.80
But problem came back after 6 months.
Its not the Overheat thermo approx £6
These are both easy to replace and test. Thermistor pull out on plastic clip.
The overheat sensor unscrew with a spammer. fiddly dependant upon how the boiler is installed as reall need space to lefthand side, or suitable box spanner.
The guy at the spares counter said its the worst boiler known to them for problems with the PCB and often is the resistors on the board apart from dry joints.
The Resistors are 6 band types. Anybody help with the values of R33, R34, R37, R38, R84, R85, R87, R88, R41 and R42?
They appear all to be the same value but colours are difficult to ascertain
Most are wired in series. BUT on my board the resistance of R37 and R38 is quite different from rest and this appear to be wired to one lead of Temperature Thermistor.
Any help would be appreciated and also where replacement resistors can be sourced from.
Finally one other thing. If you have retro installed TRV's then unless you have a Automatic Pump Bypass valve fitted (Now mandatory on new installations under Part L of the new Building Regulations) this may also cause Lockout.
It seems although the Installation Instructions for the Suprima say that 1" (28mm) Flow and Return pipework is required to Pump and a Bypass of at least 1.6m if the CH and HW circuits are controlled by Motorised Valves. Often the bypass is a 15mm constant circuit to the Bathroom Rad rather than 22mm. 15mm is not as recommended - Also this rad MUST have fully open lockshields on it to work. Yes it seems to work most of the time, but is not as recommended.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 9 times
PostPosted: Sat Jan 10, 2004 12:49 pm    Post Subject:
can you say what colour bands are on the resistors, this identifys what value it is. you should never check an component for resistance while it is still connected this is because other components wired in with it can affect the reading.
when you have got your colours sorted put them in here its easier than tell you the poem about rosie going off to birmingham which is how i remeber the resistor colour code.
you can then get new resistors from maplin
you should also get the same wattage resistor
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 7
Jump to:
Potterton Suprima 50l tripping rcd switch 3 460 Mon Nov 16, 2009 4:47 pm
POTTERTON SUPRIMA 40 - HOT WATER KEEPS TRIPPING OFF. 4 1840 Wed May 04, 2005 6:03 am
Potterton Suprima tripping 17 3540 Wed Apr 19, 2006 10:10 pm
Potterton Suprima system - tripping out - help please! 14 5440 Wed Mar 09, 2005 11:16 pm
Potterton Suprima 40 - Tripping and cold radiators 13 1780 Sat Jan 05, 2008 9:24 am
Silavent Vitalis 150mm In-Line Extractor Fan - Timer Model Silavent Vitalis 150mm In-Line Extractor Fan - Timer Model£89.92Manrose Chrome In-Line 21W Extractor Fan + Timer
Manrose Chrome In-Line 21W Extractor Fan + Timer£17.06
Vent Axia VA100SVXT12 Axial 20W Bathroom Fan Vent Axia VA100SVXT12 Axial 20W Bathroom Fan£97.23Manrose White In-Line 20W Extractor Fan
Manrose White In-Line 20W Extractor Fan£13.85
Manrose Axial 20W Bathroom Fan Manrose Axial 20W Bathroom Fan£10.13AirFlow Infrared Module
AirFlow Infrared Module£66.50
DIYnot
